Dr ZEE
Anti-Pro Circles Insider
Don't get me wrong. I am not really trying to say something against "good eq". Just trying to sort of inject some "food for thoughts"... I can see how this all may sound like confusing abstract B.S.
You've got a 'situation' you have to deal with. O.K. It may look like or maybe actually is the situation when you've drained all your options and can't get the desired result. I don't know. It's tough.
You say you need luck. Right. What I know is that you'll need luck all the time regardless of available options. So as we speak you have a 'problem', you've got some diamonds in the pocked, you need luck and you want(need?) another option in your rack. So if you spend all your diamonds you may end up in the situation where you still have problems, still need luck but no diamonds in the pocked
.... however you have another option in your rack.
See where I'm leading to ???? heh heh .... so it's pretty simple, when you shake off all the emotions.
Now that "extra option in your rack" is the subject here. You may want to try to be as reasonable about it as possible. What I basically was trying to say here is: it may be hard to be 'reasonable' in the environment where you are being driven by a passionate desire for the result and the same time being under unquestionable and unchallengeable due to its "statue nature" influences "flying over your head".
I probably do not make much practical sense...
/respects
.... however you have another option in your rack.See where I'm leading to ???? heh heh .... so it's pretty simple, when you shake off all the emotions.
/respects
