I just bought 2 of these pre's, after reading the recommendations from the people who have them, and had a couple questions.
1st) Seeing that you can't turn the power ON or OFF other than plugging or unplugging it,
how are you working around this?
I figured on running a channel strip to turn on and off, 'cus the power supply gets pretty hot so just unplugging the wire from the side of the unit would still allow the power supply to cook.
2nd) Do you think there would be a problem if I stood them up during use?
They would take up less room and it'd be easy to access the tops, but I'm not sure if this would cause a problem with the tubes being horizontal.
Thanks for the recommendations on this pre, it sounds great!!
LDT2
LDT2
