J
jeff0633
Member
I have a overdrive pedal and a chorus pedal that I really like. I want to get some kind of small floor effects box that will fit in my pedal board case and sit along side my chorus and overdrive. I need this unit for delay, reverb, and a tuner, so I need a unit like the RP100, Alesis 505II, new Behringer pedal v-amp, or something else. I won't be using the amp sims or distortions on this box, only the delay/reverb/tuner, and I will store a few different reverb/delay settings.
Any suggestions on what I might get? Here are some questions.
Can you set the 505II, or digitech RP pedals to not have amp models on? I do not want to use amp models, since I have my own distortion/overdrive. I used to own am RP100, but damn if I can remember whether you can set it to only use the effects or not. Never owned an alesisi pedal. What about the new Nehringer pedal, can you turn the amp sims off on it, and only use effects?
I don't want to use individual reverb and delay pedals, cause I wantr to have presets that I can scroll to, and still have the tuner all in the same box, yet one that stays attached to my pedal board with velcro.
Any help would be appreciated.
Jeff
Jeff
