Effects chains
  • Thread starter Thread starter Flet
F
Flet
Can you create effects chains and save them as a preset to be used on other projects (i.e. you want reverb, delay, chorus in a specific order with settings that you frequently use on all your projects)?
If so, how do you do this?
dachay2tnr said:
Not that I know of, except to use a template.
Aye, I think that all you can do is add the effects you need onto a track, make changes as necessary to each effect in the chain, and then Save As Track Template. Each time you want to replicate that chain for an audio track you Insert From Track Template.
Unfortunately, you don't appear to be able to do it any other way i.e. as say a Bus Template or as a group of effects.
