It really depends on how "peaky" the source is. If you have to set your level on a track low because every once in a while there's a giant meter slam but most of the time it barely rises, you should probably compress it to track. This will keep you from having a poor signal to noise ratio (tape) or low res digital words. If your levels are fairly consistent, you don't need to introduce noise by adding another box in the chain.
