miroslav
Cosmic Cowboy
Course, if this is a "send effect" where the verb is on it's own track, the first parameters you need to adjust are the Wet and Dry or Mix parameters. Most of the presets in Glace have Dry up at unity and Wet turned down pretty low. For this type of "reverb bus" you want the Wet up and the Dry all the way down. I usually end up with the fader on this track way down. It just kind of occurred to me that if I turned the Wet knob down a bit I could have a little more range on the fader...
Right.
I just figured that was obvious...but yeah, they set up all the soft verbs to be 50/50, which means they assume it's not going to be used on a bus....which I find rather dumb and counterintuitive for anyone having any hardware mixer experience...live or for recording.
Verbs are almost always assigned to a bus...and then you send your tracks to the verb since you would normally only use 1-2 verbs for a mix...rather than a different verb for every track.
Not saying you can't use a verb on a single track...just that they tend to be assigned to a bus.
