Hello,
first of all, sorry for my bad english.
I bought the DP-24 as upgrade of the Neo. I see the DP ambivalent.
The DP-24 looks nice and is smaller than the Neo. The new color display brings fun, but it reflects very much and if you don't look exactly from front you will not see any details. At this point is the Neo not so beauty, but also visible also from a side. The new colored knobs for effects and eq are great.
Also nice the 8 xlr inputs with phantom power in 4er groups.
Anyway, some features of the Neo I'm missing very much:
1) No way to rename tracks and virtual tracks. That feature I use on the Neo very often.
2) No way to rename marks. It's called always mark1, mark2 etc. On the Neo I can rename it and have a library for often used names like "chorus", "solo" and so on for easy use.
3) On the DP-24 I can use 8 dynamics effects at once, but only 2 if a guitar effect is used. The Neo can work with 8 simultan dynamics or 4 together with the guitar effect. That's a step backwards, I think.
4) The dynamics can assign only to the inputs. The Neo can use the dynamics also on the tracks, and then it can be per bounce printed on a new track. So I can record dry and compress it later at home. Of course, it is possible to use a effect aux pre-send per cable and bring it back into a input for recording it again compressed.
5) The virtual tracks are limited to 8 per track. The Neo offers 250 virtual track and this can be used like I want. I could use 100 virtual track as vocal takes and move them to any track.
6) The missing digital in and outputs of the dp-24 isn't a problem for me. I don't use it.
I'm wonder about the use of the record-button. For recording you need only press this button once. Not record and play simultan. This is the first multitracker with such a handling for me. I have to be wary of it.
A very good point is the working with the sd-card. Remove it from the dp-24 and put it in a card reader and you have all the tracks as wave format. Very easy and fast!
However, I'm happy to own a neo too. Would I forced to give up a machine, I would sell the dp-24 and keep the neo.
Sorry for my english again!
Best Regards from Berlin
Peter
