I've been wrestling with this DP--004 since I got it new two days ago. When I try to export any of the material I've recorded, the 004 only sees the file (SONG001) that came with the machine. Any hints?
Unless you have renamed the file, or created a new "song" with a different name, then "SONG001" is what you are working under. You can go into the menu to the "WAV" section and export the tracks that you have on the DP-004. You should then be able to see the files in a "WAV" directory once you connect it to your computer via USB.
