Does any one knows how to connect two Echo Laylas 20 Bits with Cubase 6.
  • Thread starter Thread starter moyotte
M
moyotte
I'm having problems to connect my 2 laylas 20 bits with cubase 6 using the clock sync, I hook up one of my
layla-1 clock out to the clock in of the second layla-2 then I select the ASIO ECHO WDM driver form the device set up in Cubase 6 and finally I go to Devices, Vst connections and tried to Select my 20 in and out puts of my two laylas, suddenly when I activate the in or outs of my layla-2 there is no more sound on my cubase, I can only use my ins and outs of my layla-1. I want to use all my outs from layla-1 and layla-2 at the same time because I have a mackie 24x8 mixer.
I already check both laylas separately and they are both working perfectly. One more thing I already select the my Layla-1 as the master internal Out Super Clock and my Layla-2 as my Slave In Super clock from the echo console version 6.11 beta.
Any help will be very appreciated?
Do you have the Word Clock outputs and inputs cabled correctly between the laylas
http://www.echoaudio.com/Downloads/Manuals/Archived Manuals/Layla PC Manual.pdf
Word Clock
Next to the S/PDIF ports are the Word Clock connectors. These connectors
allow you to synchronize one Layla to another Layla or to other digital
audio devices. In addition to a standard word clock signal, these connectors
also allow you to synchronize using the superclock format, which is 256x
the selected sample rate.
Yes I have the correct connectiosn LAYLA 1 CLock out to LALA 2 Clock In, I already tried using different cables.
You may want to try reversing the clock cable just to make sure which one is actual 1 and which one is 2
