Do they make such a cable ??
  • Thread starter Thread starter TascamJimi
TascamJimi
TascamJimi
Hey folks, back again with another silly question. Do they make a male stereo 1/8 mini (3.5mm ) to dual male 1/4 cable that is stereo on the 1/4 end and not dual mono ?? I thought I read somewhere it's called a ' summoning' cable that deals with resistors etc....but can't seem to find anything....Maybe I was dreaming. I bought what I thought was the above, but both 1/4 plugs carry the same mono single. I'm looking for one 1/4 to carry the left, and one 1/4 to carry the right .
The reason I'm asking is two-fold:
1. I'd like to be able to pull a stereo single off my phone into my DP-02 in case I want to record some sound effects ( in stereo ) of the internet etc,,,
2. I'd like to try running a full 8 track mix out of the DP-02, into my Zoom H2N, then back into 2 tracks of the DP-02. The H2N has an 1/8 9 3.5mm ) stereo out.
I'm good with a soldering iron so I could easily make my own if I could find a schematic.
This is the one I purchased, but again, it's dual mono on the 1/4 inch side......need stereo
I hope this all makes sense !!
Jim
I think you have what you need. One end is stereo and that is split for left channel/right channel. When they are split, they are considered mono aka not stereo each.
A Hosa Y C able 1/4 in TRS to Dual 1/4 in TRS - and an Adaptor.
iu
+1. Assuming it's wired correctly, what you bought is what you need.
"1/4 cable that is stereo on the 1/4 end and not dual mono"
Not sure what you mean by that. The layout is as follows...
1/8" TRS - plugged into a stereo output.
Tip - Left
Ring - Right
Shield - Ground.
2 X 1/4" TS - each plugged into a mono input.
Tip - Left
Shield - Ground
and
Tip - Right
Shield - Ground.
If you have a multimeter you could confirm your cable is wired correctly, following that ^.
You are not looking for a summing cable.
You are looking for a stereo breakout or an insert cable with 1/8 TRS to two 1/4 TS.
Thanks so much for the replies and PATIENCE !!! What's happening with the above cable, is the two 1/4 inch plugs are receiving the same signal. If I cue up Van Halen on my phone, Eddie is hard left, and Michael is hard right. But when I plug those 1/4 plugs into tracks 1 and 2, I get a mono signal on both with no stereo spread on the 2 input channels. I want what's on the left to stay on the left, ( track 1 ) and what's on the right to stay on the right ( track 2 ) I should read up a little on TR vs TRS jacks and plugs as it might help understand what's going on....
Again THANK YOU for being patient with all the silly questions I've been asking.
The cable you have really should be what you need.
Try just plugging in just one of the 1/4" cables, with a very obvious stereo track like you describe.
If Eddie, or Michael, disappears then you're getting left and right separately but just not panning them apart at the input device.
If you still hear everything, then most likely that cable isn't wired as I described - The way one would expect it to be wired.
I tried to grasp what you're after, but am still confused.
Reading your last post, TascamJimi, I think you just need to use the pan knobs to pan to pan Eddie left, and Michael Right.
What are you using for Playback? IOWs what is the two mono cables plugging into? If it’s a Mixer - then are you panning hard right and left on the two channels? if it’s something else is there a Mono switch on it? For example my headphone amp can sum to mono or stereo.
Now this is getting stranger and stranger.... Thinking it's not a cable issue after all.... @Steenamaroo , I tried what you suggestion and it worked as far as plugging one cable in at a time. With just one in, I indeed got one side of the stereo split, disconnected it, hooked up the other and yep, got the other side of the spectrum. BUT, when I plug them both in at the same time, record a bit, I get same thing on both tracks no matter if I pan hard left and hard right. I recorded in both the mono and stereo settings on the input mode DP-02 Same result. I'm thinking I might be missing something with the recorder but dang.... I'm stumped...
@Slouching Raymond , There are times when I hear some cool effect, or thunderstorm stuff on Youtube , or any device with a stereo 1/8 out, that I'd like to be able to bring into my Tascam ....in stereo...
@Papanate I'm just using the headphone jack on the Tascam, The only way I thought I could pan the inputs is in 'stereo' input mode, but it didn't make any difference what position the switch is in. Upon playback there's no difference panning left and right no matter if the input was in stereo or mono mode.
I apologize again for confusing the heck out of everyone...... Still learning this machine..... I will say the 488MKII I used years ago was a lot easier..... but digital is much better when you bounce , RW and FF as much as I do..... :O)
