A
alevy
My chain is eq,noise gate,compressor,reverb,then the deesser. Is that the right order.
alevy said:My chain is eq,noise gate,compressor,reverb,then the deesser. Is that the right order.
I'd say no.... your "chain" should be different for every context.... if something is not used in a particular application, it has no business being in the chain......alevy said:My chain is eq,noise gate,compressor,reverb,then the deesser. Is that the right order.
ragata said:noise-gate -> de-esser -> compressor -> EQ -> reverb
To work well, the de-esser needs to be able to catch the sibilant peaks... if you compress first, the peaks are far less obvious to the de-esser and it won't be effective....mixsit said:Wouldn't you want the compressor before de-ess? My reasoning is to have the larger level changes evened out so the de-ess threshold can be more moderate.
Not that I uses it all that often though...
Wayne
ecktronic said:I would have thought to put the deesser at the end of the chain so that any EQ boosts are caught by the deesser rather than deessing then boosting the EQ and getting sssss's again.
Ive never been able to use the de-esser plug-in well, it just makes my vox sound muddy. I love the de-esser on the Boss BR1180 though!!! it gets rid of sss's really well without changing the tone much.
Blue Bear Sound said:To work well, the de-esser needs to be able to ctach the sibilance peaks... if you compress first, the peaks are far less obvious to the de-esser and it won't be effective....
Ah yes.. unless you're going for those breathy-sizzle trails in the verb.. Remember that old Andy Williams sound...bennychico11 said:well a desser helps you find the high frequencies....like 7kHz on up. You might not always EQ the vocalist at those frequencies since they usually don't get that high (that's why the sibiliance resides in that area). A general rule I follow....correct before adding. in other words, correct mistakes in the sound before adding effects to boost the sound. You remove sibilance, that annoying ringing noise coming from somewhere, rumbling of the A/C, etc. BEFORE adding EQ to complement the instrument.
