Whether I use a lot of eq after the fact generally has little to do with the preamp I used. Usually, if I have enough time to adjust the source sound and have the right mic for the capture, I can get EXACTLY what I want going to tape. This holds true no matter which preamp I use. It seems that these two "little" things are always forgotten.
We have a Focusrite Red at the studio. It get's used on almost NOTHING anymore. Overheads and the occasional acoustic guitar track. I have a very hard time with that preamp sounding "warm". I find myself eq'ing out a LOT of high mid's on any source I put through it. It does do the trick when I need to give a sound more edge while tracking, but I usually prefer to just get more edge out of the source.
I usually track vocals using a Oram MWS preamp/eq box. I generally also use a 4050 as the "go to" first mic. It is usually a very good sounding combo, and is even better with a Drawmer 1960 compressor after it. The other day, I had a vocalist that just sounded horrible on the 4050. The AKG 414 sounded much better on him. But, the 414 sounded horrible on him via the Oram. I used
the Drawmer 1960 preamp/comp and everything sounded good! On most singers, this combo would be horrible. You know what? The ADK Tc51 via the Oram sounded almost like the 414/Drawmer. I went with the 414/Drawmer because I had a little more exact gain staging I could do (the ADK doesn't have any output sensitivity selection..the Drawmer doesn't have "fixed" gain stages like the Oram). So really, either combo could have worked, but the one I went with allowed me a little bit more gain control
I will contend here that most of you here would make very different decisions concerning which combo you would have used. You all might have heard things quite differently than I did. That is all cool. The fact remains though is that on any given day, a different mic/pre combo is going to work better for some things than others.
Like mic's, I use preamps to achieve different things. I would love to add about, oh, 20 more different preamps and 100 different mics to the mix at the studio. That would rock! But that is expensive.
All I have ever really stated here is that the ART is as capable on any given day as just about ANY other preamp on the market. It is a good sounding preamp. I base this upon over 6 years of using it on a variety of things.
If you are JUST going to buy ONE preamp, get whatever you want. It is NOT going to be any better or any worse than any other decent preamp in a overall way! I have done recordings that sounded great using almost nothing BUT the ART. These recordings have sounded better than stuff I have heard using almost all classA pre's. What was the difference? The pre's? I doubt it. Maybe I just took more care to get the sound I wanted, whether that meant changing the source sound, and/or the mic.
In the end, most "decent" preamps can help you achieve your end result.
What I like about the ART is that it has variable control of the input and output.
The Pro MPA also has an adjustable High Pass Filter. That is very useful. I have never experienced the types of problems others have described about the ART in my 6 years of dealing with these pre's. I also haven't experienced many of the problems many describe with
the Alesis 3630 compressor either! So, explain to me why there is a difference between what I have done with these boxes and what others have done with them?
My experience with listening to people's mp3's is that a lot of the audio I hear sounds sort of stake and cold. Is this the source sounds? Effects of their monitoring environment? The A/D converters? The mic? The preamp? The processing they do after the fact? Probably a mix of all the above.
My point is simply this. If you are looking for a solution for everything in one box, you are going to be sadly disappointed. A good engineer is going to get very good results no matter what they use. The ART is not always the first box I grab for, but if I had to buy 8 channels of something on a budget, it would be the first box I would buy! On average, it works out very well.
Ed
