Discharging Filter Caps, the Gerald Weber way
  • Thread starter Thread starter the_crowing
T
the_crowing
Hey guys, reading Gerald Weber's "A Desktop Reference of Hip Vintage Amplifiers", I read about his method to discharge filter caps, but I haven't seen it recommended or even talked about anywhere else. He says: While the standby switch is in the play mode, use a simple jumper wire from the plate of any preamp tube to the chassis, then from the plate of any power tube to chassis, waiting a few seconds for each. The electricity should be drained.
Anybody ever used that method? Is it simpler/safer than the "probing method"?
Nope, I've always gone by the "unplug the amp before I go to bed and mess with it in the morning" technique. ;)
It works fine. You start with the preamp tube because they have plate resistors that will drain the caps at a less-than explosive rate. :D If you hooked a plain wire from the caps to the chassis when the caps were fully-charged, it could be pretty exciting!
"A few seconds" seems scarily vague. Meter the caps before you move to the power tubes.
sustain a chord and switch it off... IF there's any left just short it...
I don't think that playing as the amp goes off is a reliable method. When the heaters cool down, the tubes stop conducting even if there is charge left on the caps.
I have a couple of 25 0hm 10 watt cement resistors in series. I have an alligator clip soldered on one end and hook that end to the chassis. The other end I touch to the filter side or the standby switch or the + side of the filter caps. It will drain the caps in a couple of seconds. I always measure them before working in the amp to make sure they are fully drained.
they dont cool off that quickly!!! and there's not that much current either... and i also suggested shorting what was left... i worked on them professionally for like 18 yrs and ive been bit a few times but never from a guitar amp when i did this.... i did get thrown across a room one time working on an old hammond amp that was live... 600V.... yee haaa.....
A small bleed resistor between cap and ground has never failed me. Don't know about grounding the plate, especially in a grounded-plate design. Even with a "fail-proof" method, it's always best to check and make sure.
This is what I use. There's a 100k ohm resistor on the end of the chopstick.
That's a pretty slick little tool. I'm gonna go make one!
Does the alligator clip just connect to chassis? Newb question! Also, has anyone done an isolation transformer install on a Supro Bantam?
Yes, the alligator clip connects to the chassis. I like to use test leads with alligator clips on the end. I cut the test lead in half and solder a 100k or 150k resistor between and cover it up with heat shrink. One side clips to the filter caps and the other clips on to the chassis. Drains in seconds. **Word of caution, DO NOT FORGET TO REMOVE THE CLIPS WHEN POWERING UP THE AMP**. I like the chopstick one, gonna have to make one of those. :)
Thanks! I've seen the screwdriver method, but sparks scare me. I think your design and the chopstick one are neat, will definitely try. Drumslinger: any ideas re: supro bantam? lots of the web stuff is contradictory and I was just quoted 60 dollars to install the iso transformer....seems steep!
brian,
Never modded the bantam but i do know of them. Transformerless amp, two prong plug, death cap and voltage going straight from the wall to the tubes. The amp needs modding to make it safe hence the 1:1 iso transformer but you will also need to have a 3 prong (grounded plug), death cap removed and fuse wired to the transformer for extra safety. **Don't trying playing the amp barefoot on concrete unless you have a death wish**. If it's $60 for the whole modding with parts then it's a decent price AND he can give it a good look over for any potential hazards.
