T
		the_crowing
Hey guys, reading Gerald Weber's "A Desktop Reference of Hip Vintage Amplifiers", I read about his method to discharge filter caps, but I haven't seen it  recommended or even talked about anywhere else. He says: While the standby switch is in the play mode, use a simple jumper wire from the plate of any preamp tube to the chassis, then from the plate of any power tube to chassis, waiting a few seconds for each. The electricity should be drained.
Anybody ever used that method? Is it simpler/safer than the "probing method"?
  If you hooked a plain wire from the caps to the chassis when the caps were fully-charged, it could be pretty exciting!
