specs
I have read now, thousands of articles on home-recording studios. I am still far from competant but I think I have the hand of it all now. My question is: Is it correct to purchase a Digital Multitrack recording machine without a new soundcard, or do you have to use both for clarity? As far as I understand it is important to make sure your signal changes from a/d d/a only twice if you can and once if your rich!! My factory soundcard has an anolog input which converts to digital inside the comp. (I believe this is correct). If I purchase a digital multitracker won't the signal change three times (instrument(analog)-mixer(analog)-multitrack(digital)-soundcard(analog)-soundcard(digital). I also read somewhere that you should keep analog signals from inside your comp because it picks up unwanted noise. In the above configuration wouldn't the unwanted noise get in? If I purchase a new soundcard with s/pdif(I think) then I assume I can run a digital direct line to the soundcard from the multitracker which would cut out one of the conversions. Is this correct or am I out to lunch? Well I'm out to lunch but is it correct?
Thanks
Specs
Thanks
Specs
