Farview
The difference is that mixing is mixing and mastering is mastering. The goals are different.Change of POETS said:Ok then... so what about mastering?
When I EQ/Limit/Compress my final mix in the mastering process, I apply gain to increase the overall volume of the track. I limit to -0.1 db as to avoid any digital distortion from encroaching the 0db mark. Essentially speaking, isn't adding gain to a final mix, the same as adding gain while in the mixing process?
If we left everything at -6db we'd have extremely low-volume CD's, which most people won't want to purchase.... right?
You will find that if you leave the headroom in the mix, when you go to master it, it will always sound better. When eq'ing, even subtractive eq'ing, you are adding gain. If your mix doesn't have any headroom, you will take the chance of clipping the eq and everything else down the chain.
Mixing and mastering are two different processes, don't try to get a finished product before you are finished.
