Hi,
I run pro tools on my 001, and can say that it is rock solid.Most of the griping on the duc has nothing to do with performance but
1.in a infamous marketing desicion digidesign decided to take out smpte, as well as limit other features on the software.
2.On pc there are no asio or direct x drivers, so if you wanted to do something like run fruity loops on the 001 your shit outta luck.On mac the asio and mas drivers are inefficient and dont allow low latency monitoring.
Also the midi interface that comes with it isnt great.But, I personally havent had any troubles with that.
So what is up with the 001?
Digidesign makes noithing but rock solid software for professional needs. Unlike some companies(steinberg, cough, cough) they dont use their paying customers as beta testers.For recording,editing and mixing audio its a potent package if your cpu is up to the task.
Pro tools midi is less then plush.If your thing is deep midi editing then youll want something different.For this department you can use logic audio on your 001 and it shoul be pretty darned cool( but this is where the midi interface problems have arisen)
Its good for the price.If you want t\o spend a little more you could do better, but theres little as solid and well conceived as pro tools.
A lot of the griping about digidesign is to do with their bull headedness in lack of support for other formats wich makes it hard if you want to use apps like acid, or cubase with your 001.
Look at motus 828 firewire interface, using that with dp 3.0 would be more flexable then the 001 I'd think.
http://www.motu.com
