Different tones from different DIs?
  • Thread starter Thread starter businessnotplea
B
businessnotplea
I've been recording bass and experimenting with different ways to do it. I believe I'm taking 2 seperate DIs (different takes) but one is clangy and rich in high end, and the other is deep beautiful but has no bite.
The first was taken from a behringer mic200 tube preamp, this box has a DI facility which sits between the bass signal and recorder, it has lots of clangy 3khz, it sounds more top heavy but a spectrum analyser confirmed it was actually a quite well balanced frequency range. It gave an unimpressive thin bass sound.
The second was taken from a Trace Elliot bass head with a DI ouput directly on the amp itself. This sounds beautifully low and looks more like a desirable signal (In the bass range anyway) but the mid/high midrange hardly registers for the high end. Any ideas please? Should I just try to Eq bite/presence into it? All were recorded flat with no Eq, compression etc. Thank you.
Most likely it is not the DI component, but what comes before that that is giving the differences in tone.
Try micing up the amp for some real good bass recordings.
Good point gecko, there is a "Pre-shape" switch on the bass amp, I did use one of these but every setting including off is so deep and bassy with a subtly high end. Perhaps this is the answer.
I did mic it as well actually moresound, I was getting a lot of hiss from the mic though due to the low levels the bass cab had to be set at. Thanks for your responses
