Did I buy a dud?
  • Thread starter Thread starter Seamus O D
Seamus O D
This is for any Behringer Truth Monitor users out there.
Ordered a Truth B2030A and got it yesterday. Opened it up, plugged it in and without connecting it to anything else, switched it on. Dead as a doornail. The little green light failed to come on.
Read the manual which said you have to hook it up correctly before you switch it on (using TRS cables), but common sense would tell me if you plug it in the light should come on, no matter what cables you’re using.
Don’t think the power source is a problem because I’m happily running a computer, mixer and guitar amp from same source.
So am I doing something wrong or should I send it back?
Well, at least try it...
If it doesn't work, check the fuse (if there's an external fuse).
Does the other one work?
