Delta 66 problem
  • Thread starter Thread starter HassanNaeem
H
HassanNaeem
Hi...
I'm having a problem with my delta...i have my delta 66 hooked up..which my studio monitors going into the outputs..and running protools m-powered..whenever i play sound through pro tools or any song on my computer for that matter...i get this skipping sound..it distorts and skips at certain points when im guessin the computer loads a bit...can anyone help me with this problem..thank you
Can you list a little more info about your computer, such as cpu, ram, OS, and if there are any other devices hooked up to it? Is this computer used for recording only, or is it an all around internet etc. computer? Is the internal soundcard and any graphics acceleration disabled? Are you using ASIO, wdm, or other drivers, and what are your buffer and latency settings?
Asus P5K Motherboard
2GB Ram
Windows XP Home OS
delta 66 sound card
nvidia 8800gt sound card
the internal soundcard is NOT disabled
im also runnin m-audio revolution 7.1
I also use internet on it
The graphics hardware acceleration is FULL with write combining enabled
1680 x 1050 (32 Bit colours)
im using ASIO drivers for the delta 66 on reason
96/24 bit
Pro tools settings
DAE Buffer size 1500 ms; Level 2 (Default)
Cache Size: Normal
H/W Buffer Size: 512 Samples
RTAS: 2 Processor
RTAS Engine
enabled --> (Ignore Errors During Playback/Reord (may cause clicks and pops)
disabled --> Minimize additional I/O Latency
Audiosuite:
Buffersize: small
enabled: Use AudioSuite Dither
Plug-in digidesign dither
bit depth: 24 bits
TC/E:
TC/E Plug-In: Time Shift
Elastic Audio also enabled
Delta Mixer
ASIO/WDM Buffer Size
256 Samples
Mode - professional
emphasis - not indicated
data type - audio
scms - can't choose
enabled --> disabl asio direct monitoring
output source --> sw rtn (should i change it to mixer?)
