Well, I don't really know much about mic pre's to be honest. I'm going to be using these mics to do vocals for an EP, so I want the best sound possible. I can probably borrow a pre-amp from this store as well- regardless of price, what kind of pre should I look for? (Going to be saving up for whatever gear I need, so price isn't really an issue at this point.
Thanks
Well pre amps are probably the most expensive single piece of
equipment you purchase and the ones most people will recommend
usually run in the $1500 on up range. You'll want your preamp to match
your mic and your mic to match what ever your recording.
How many tracks you going to be recording at a time? 2? 4? more?
I picked up a UA DCS portable mic pre 2 channel a month or so ago that
seems to be doing a good job and has a lot of bells and whistles. They
go for $1000 to $1200 so that would be $500 to $600 a channel.
Also Sytek has a 4 channel pre for around $900 so that would only be
about $225 per channel. I really think these are about as low as you
should go. Also both of these pre are extremely clean with almost
zero coloration which can be a good thing or a bad thing depending on
what your recording.
I guess the other things to know would be the place your recording in
and what your using for monitors.
