J
		Jags
OK, I've downloaded db-audioware with the intention of increasing the volume of my final mixes (on a recommendation from here).  My question is, should I first mixdown the song to wav and then use the mastering limiter plugin on the single wav file or should I apply the mastering limiter (dbml) when I am mixing down the song?
My biggest problem is that because of the number of plugins i have applied to the tracks, the computer can't handle playing through the song with them all on (i assume it's a performance issue at least?), so I can only run through the song with the plugins off, therefore it's difficult to know whether or not the volume is breaking the 0db level when the plugins are on. With that in mind would it be safer to use the dbml while mixing down, or would i get a better result by just using a normal plugin limiter while mixing down and then using the dbml on the wav? Would it even make any difference? Sorry if this seems confusing, i hope you can see what I'm trying to say .
Thanks
Jags
.Thanks
Jags
