E
emomusician
I bought a firepod so I could record drums finally on seperate tracks. It came with Cubase LE. I was using adobe 1.5 but apparently it doesn't work with the ASIO drivers of the firepod. So I can either switch to Adobe 2.0, or use Cubase LE.
I'm recording mostly band demos of local bands. Should I stick with Cubase, switch to Audition 2.0? or is there something better thats equally as intuitive?
I had issues setting up cubase to see all 10 channels.. but I found a cubase template that had it preconfigured. So I need something easy to set up with the firepod.. to record 8 tracks simultaneous.
any reccomendations? I'm gonna be using drumagog as well.
Good luck!
