There wasn't much sense in upgrading without a machine that would run the upgrade..
Anyways, I think your problems are from waiting too long between upgrades.
Not sure I follow. I do still have old machine, which is running 32-bit Sonar 6. It cannot run X3 in either 32-bit or 64-bit, since it requires at least Win 7 and the old machine is running XP and cannot run Win 7.Do you still have the old machine? If so, you can upgrade there, resave your projects and then transfer to the new system. Will save some of the headaches.
It should be 100% and then set the mix on the send, rather than the plug. At lest you wouldn't have had to deal with that.whether it was 20% wet or 30% wet,
I do set it to 100% on a send. But sometimes I only use it on one track. Never saw the need to set up a send for those instances, when you could just patch it into the track and reduce the wetness.It should be 100% and then set the mix on the send, rather than the plug. At lest you wouldn't have had to deal with that.
I'm guessing it's your version, because I have no problem using 32 bit plugs, DXIs or both, but I'm just not using them, or even the DAW for that matter.
If anything, now you can get some mixing practice in.
That's actually a pretty good idea. It won't work for the ones not available, but will work for the ones that simply have new names. That's essentially the Waves plugins, but I tend to use them a lot.Doesn't you old rig run? You could just check back on it. Of course if you can't use the old plugs the point is moot.
Did you look at the link I gave you above?I'm guessing it's your version, because I have no problem using 32 bit plugs, DXIs or both, but I'm just not using them, or even the DAW for that matter.:
Plus, when I went to install some of them from the prior version of Sonar, these specifically said "32-bit only." At first I thought that meant they only came in 32-bit versions. But now I'm pretty sure it meant would only run in 32-bit environments.
I'm sure there are many, many plugins better than those. It was just not wanting to have to reinvent the wheel when I already had a sound I was comfortable with.Have you tried any of the newer bundled plugs? There's a possibility if you heard them side by side with the new ones you might not want to go back. Those plugs were limited by CPU considerations, it's a whole new world now, your phone is more powerful than your first computer.
My mother had a mastectomy on Monday. Hopefully that will get rid of the cancer. She came through it remarkably well. Released from hospital yesterday and was up and around immediately.
I'm hoping I'm in as good a shape at 89.
Don't even need to do that. I could install the 32-bit version of X3 alongside the 64-bit version. In fact, that's Cakewalk's solution to the issue.SONAR
Did you ever think about installing your old version along with the new?
LATER!!!
Back atcha!!!Happy Memorial day weekend!
LATER!!!
Back atcha!!!
so there won't be much drinking.
My brother and I agreed to split an Uber to get her home, as it would be unamerican not to drink.Don't worry, I'll pick up your slack.
l]
A big shout out to the veterans who made this all possible.
