DAW transport control foot switch?
  • Thread starter Thread starter paresh
P
paresh
Member
Is there such a thing? Sort of a control surface foot pedal but all I need is the transport control to free up my hands. Thanks.
Behringer FCB-1010 can output any midi command from any pedal (figuring out how to program isn't fun, but once its done you're in...)
Any DAW program that can be programmed to respond to midi for commands would work.
(I always used to use the upper half-dozen keys of my 88-key keyboard with NTrack for basic commands - never used those keys in any music anyway...)
Ditto
I currently have a Mackie MCU which takes a dry contact closure into the console and sends a midi message to the DAW but those are a bit spendy. Most recording applications will let you use any inexpensive midi device (like a keyboard or other desktop controller) to do this. Depending upon the application (recording software), it may be piece of cake or a little midi hacking may be required.
Speaking of cake :D . I'm using SONAR which is one of the "easy" software packages that allow this. It has a "learn" function.
Here's a couple ideas;
http://www.midisolutions.com/prodfsw.htm
http://www.zzounds.com/a--2676837/item--BEHFCB1010
Hello Paresh,
There is a new foot control on the market, called a Pok.
It is basically a wireless remote control pedal, using your sofyware's keyboard shortcuts. It transmits whatever keystrokes you want to your computer, when you press the buttons with your foot.
Much easier to set up than a midi pedal. Of course, it can do transport as well as any other commands available via keyboard. It's at www.x-tempozone.com :)
