I
Ironklad Audio
if you can get the lunchbox for free with the modules, i would say go for it. if not, i would go with the 3124....but that's just my personal opinion
When you guys use the API's on drums (the 512c's) how many channels do you typically need?
For example, are you running Overheads + Snare + Kick (4 channels) of API or are you also using API's on Tom's, under the snare, etc.
I only use around 4 mics on drums anyway... but, how do you guys afford enough pre's for 8 or more mics setups ?
... Better to track drums in a good room... You can use better pres for overheads, snare, etc., but mic up the rest through a board of your choice (Allen & Heath, Midas, Wackie, etc.) Probably the cheapest per channel arrangement, and frankly, more convenient that using lots of one and two channel pres.
As much as I do like the Sytek preamps, I am not sure I would consider them to be a huge step up form the Mackie Onyx preamps. The older Mackie preamps I would, but the Onyx is definately nicer than the VLZ crap. In fact, the Onyx almost has a Sytek'ish vibe. That kind of neutral but still a little smooth sound. On drums especially I would imagine the Syteks and the Mackies sounding closer in sound than on other sources like vocals, acoustics and even electrics where the differences would start to become more apparent. Also, "punchy" is definately not what I would use to describe the Sytek sound. This to me would be more of the API sound. Fast response with a low mid aggression. I could see calling a Neve style preamp punchy but it a different way.
