B
Buzi
hi all.
I've got an annoying problem I'm dying to solve.
Help PLEASE !!!
I've got the following :
P4 2.4Ghz with 768Mb RAM.
Delta 1010 (just the pci card)
Yamaha 12/4 mixer
Windows XP Pro w/SP1
I use Cubase and Reason 2.0
I've got the Delta1010 vard on 1 pci, and some USB ports on another.
I've got Reason rewired to cubase and I'm using about 6 channels in cubase so far. I've got 2 of Reason's soft-synths and Reason's Dr.Groove drum machine going into Cubase. The synths each go into a 2 channels , and a KICK and SNARE onto seperate channels.
1st question -
During playback, I've got Cubase looping on 2 bars for constructing the drums sequence (Reason's drum machine). Whenever Cubase's marker goes back to the beginning of the loop ( "L" marker ) it plays both kick and snare samples at once...causing clipping. The drum sequence should only play the KICK on that spot.
WHY IS THAT ???
2nd question -
This problem started just recently (I just installed a new motherboard) :
Whenever I play the track there's clicking sounds when I've got the Cubase window in front, and when I switch to Reason, the clicking stops and everything's fine.
I get alot more clicks when playing back the mix and moving the mouse around, or opening a menu or scrolling across the virtual mixers.
I've tried changing sample rates, buffer sizes,...nothing works.
I'm using the Maudio ASIO driver
When I put the soundcard on a different PCI slot the computer doesn't even recognize it and tells me that the hardware couldn't be found (wierd)
What could be causing this ????
thanks alot for your help!
Buzi
Help PLEASE !!!
Yamaha 12/4 mixer
1st question -
WHY IS THAT ???
2nd question -
Buzi
