Cubase synch problem
  • Thread starter Thread starter detlef
D
detlef
Hello all
I'm really glad I had found out this bbs; I got a problem with Cubase, and hope somebody can help.
I run Cubase SX with a brand new Layla 3G. It seems all ok, until I try to synchronize via midi clock a couple of external devices ( a drum machine and a sampler).
The synchronization starts perfectly, but when I push the 'play' button in the transport panel, the audio (from the external devices) cames with a lot of clips and noises.
If I disable the midi clock and start directly from the machines the clips seems to disappear, and everything works perfectly, apart the fact that I can not synchronize my toys.... :(
Any suggestion?
Thanks in advance
Check to make sure you assign a master and a slave.
Make sure all have the same sample rate in every toy you have when syncing.
Otherwise i'm clueless.
Hope that helps :confused:
