F
fenderdude
I am thinking of getting a crossover to boost the bass of our band via a subwoofer. But here are a couple of questions:
I run a Crate PA is the main brain, it has two internal amps that I use to drive monitors or FOH speakers. I also have two amps in a rack setup with an eq. I was thinking of adding a crossover, using one of the amps to hook up a subwoofer via the crossover and the other amp for mids etc. Is this ok to do? In other words, I won't be using the highs of the crossover, just the mids and bass.
Or....another config, could I just use the mid and high parts of the crossover and not use the sub? In other words, I would run the lower frequencies to one set of FOH speakers and the Mid/high to another set and not use the sub. Any ideas?
Fenderdude
Fenderdude
