Not the drum set....all your other instruments.
Use the rack comps/EQ for your tape instruments....guitars, bass, whatever....or save all the processing for the DAW plugs, whatever you feel like.
Get a DAW drum sampler, like
EZ drummer (very inexpensive.).
Drop a single scratch drum track from the DAW on one tape track.
Record all your other instruments to tape using that as your beat....(or you can also just use a click track for that).
Dump them all to the DAW and then add the final DAW sample drums, using your scratch tape drum/click track to get it all lined up. Since the tape deck would run free during dump to DAW, there will be some very minor speed fluctuations from the deck, but the DAW drums will be in perfect time, so you have to nudge something, and it's easier nudging the DAW drums instead of all the tape tracks, but you could do that too, whatever feels easier....but I bet you would need to do very minor nudging here and there to line it all up once in the DAW.
After that, for the rest of the tracks/mixing...stay in the DAW and forget the rack gear and the tape deck.
That would be a nice hybrid setup, allowing you to use tape on 7 tracks, then mix them individually in the DAW with DAW/MIDI tracks from the DAW and/or recorded direct to DAW.
Any of this making sense...?
Oh...and forget the whole "virtual instruments" approach. I ran with that back in the early '90s for a couple of years...and then at one point, I was looking to remix some stuff, and trying to get all the virtual instruments back the way they were was a PITA, even though I wrote down settings and saved presets....that "virtual" stuff has a tendancy to turn into vapor.
By getting everything in the DAW as a record audio track (including the sampled drums)...you can then archive all those WAV files, and pull them up 10 years later into any respectable DAW and remix again from scratch....but with virtual stuff....what if that synth module you used on some song just ain't working any more......
