B
		BenignVanilla
I keep seeing "treat your corners, make them at least 4'' thick". Lucy, some splainin' to do please?
			What would you like explained? The panels have to be at least 4" thick before they'll start working low enough. 2" panels wil only get down to about 250Hz-350Hz. 4" panels will get down as low as 70Hz.
			Four inches of what?
			Mythbusters just showed how to make a car bulletproof with phone books. Would 4" of phone books trap bass as good as they do bullets?
			I would suspect that the material matters before the thickness, which is why I asked. Four inches of what? It just seemed like a mantra, so I was curious what was behind it.
			i see a mythbusters follow up in the near future.
The reason these products work vs phonebooks is DENSITY. The density of these products is around 3 lbs per cubic foot. The simple answer to why density is important is because these type absorbers are called RESISTANCE absorbers. They allow air molecules to move within the "interstices" of the fiberglass fibers(gas flow), which at 3 lb density, is just enough to provide a resistance to this movement when the air molecules are excited by a sound source. This resistance results in absorption of the energy which is transduced into heat. No different than rubbing your thumb on your jeans.Rigid Fiberglass or Rockwool. Owens Corning 703 is popular. Knauff, Johns Manville, etc have comparable products. Roxul Safe is a comparable rockwool.
There's evidently a denser version as well, where 2" will give you the same trapping as 4" of 703, but it's more expensive as I recall.
__________________
 However, I'm always willing to learn.
 However, I'm always willing to learn.It depends. If big enough, as a membrane absorber.... maybe at 1hzDo you suppose that would make a good bass trap?
Oh, sorry - almost every tutorial I've ever seen specifies OC703 or some equivalent under a different trade name. There's evidently a denser version as well, where 2" will give you the same trapping as 4" of 703, but it's more expensive as I recall.
			 as well, which as you can see has been filled.  This also illustrates the use of basstraps at wall/ceiling intersections.
That's the right answer. Rigid fiberglass or mineral wool with a density between 48kg/m3 and 60kg/m3 is best, but if you'd trying to get down really low, then less density but more thickness and airspace is better.
 Which is it? Less density or more.
			Ok, just to illustrate the use of 703 as basstraps in PRO studios, here is a GIANT basstrap at the wall/ceiling intersection of Manifold studios CR. This one will absorb down to 50hz(according to the designer). It hasn't been filled with many layers of 703 yet, although there is an area behind it that is over 5' deepas well, which as you can see has been filled. This also illustrates the use of basstraps at wall/ceiling intersections.
You can make a car bullet proof with 1/2" of carbon steel. Do you suppose that would make a good bass trap?
			I kind of follow your logic, but let's take it a step further. If you've ever been in a warehouse or storage area for steel, you'll know that it's generally a pretty noisy place.You can make a car bullet proof with 1/2" of carbon steel. Do you suppose that would make a good bass trap?
the library. Very quiet.
			....speaking of which...I was at the corner store the other day, reading a magazine. The clerk looks at me and says "Hey! This not a library". So I said "OK! I WILL TALK LOUDER THEN!!!!".
			Gaaaaahhh...plywood on the console with the meterbridge uncovered...makes my chest hurt
 Talk about pro? This is as Pro as it gets. Absolutely stunning. If you can stand a dose of reality checks, look at the whole build here.
 Talk about pro? This is as Pro as it gets. Absolutely stunning. If you can stand a dose of reality checks, look at the whole build here. Unfreakingbelievable. Who says big studios are a thing of the past. But it sure takes some DEEP pockets
