connecting compressor
  • Thread starter Thread starter daveblue222
D
daveblue222
how would i go about connecting a compressor or e.q to the alesis io 26
http://www.alesis.com/io26
look at the pics to see in the in/outs
it says in the manual to use the inserts below each mic input for compression units etc.. id imagine that the compresser would only compress the track its plugged into?
now with the presonus firestudio project connection for compressors, e.q units is on the back, which seems it would effect every track.
http://www.presonus.com/media/diagra...and EQ3B.pdf
am i right or would it be possible to use external units that effect all tracks on the io 26
sorry if this sounds like a stupid question lol
thanks
On the front panel of the io 26, there is an insert for each channel. A TRS cable from the io 26 to your effects. There ought to be a TRS on your device labeled 'output' or 'balanced'. Something like that. Or, plug your mic into the EQ or compressor, and then into the channel input of the io 26. That's how I do it, but try each way and choose what you prefer.
