Tascam Rack Mount List (1980’s)
  • Thread starter Thread starter yoshi420
Y
yoshi420
Hello all, I haven’t found this information anywhere else on the internet, so I thought this would be a good place to share it.
below is a list of all the Tascam rack units through the 80’s (not including cassette decks like the 234 or large racked mixers like the mm1). I’ll add some notes from my experience with the units if I have anything worth adding.
TASCAM 1U RACK EQUIPMENT LATE 80’s EARLY 90’s (Japan)
Tascam GA-2020 Dual Sync Noise Gate
Tascam RS-2000 Digital Reverberation System
*buttons are prone to falling off, they can be replaced with the buttons from the Vesta Fire rvd-901 or the Vesta Fire dig-412b. both units are much easier to find than the RS-2000.*
*the Vesta Fire rvd-901 is virtually the same machine as the Tascam RS-2000, aside from the different inputs/outputs. Vesta Fire rvd-901 has 1/4in jacks and an effect send/receive. Tascam RS-2000 has both 1/4in and rca inputs and outputs with no effect send/receive.*
*The rvd-901 has an available manual, which can be applied to the RS-2000 for the most part. https://www.manualslib.com/manual/1332210/Vesta-Fire-Rvd-901.html?page=4#manual *
Tascam DL-2000 Dual Compressor/Limiter
*I have not seen the internals for the Tascam DL-2000 or the Vesta Fire SL-200, but they look identical and have the exact same input/output and potentiometer layout.*
Tascam GA-30 Graphic Analyzer
“TASCAM NEW STUDIO COMPONENTS” 1983 (Japan)
Tascam RS-20b Dual Reverberation System
*I’ve seen 4 of these. 3 of them needed to be recapped.*
Tascam DL-20 Dual Compressor Limiter
Tascam CF-20 Dual Chorus/Flanger
Tascam GA-40 Quad Noise Gate
“TASCAM SYSTEM ENHANCEMENT SERIES”(1983) (US / JAPAN / EU)
Tascam MX-80 - 8/2 Mic/Line Mixer
*this unit was supposed to have an adapter which would turn on the internal phantom power, but it was never released.*
Tascam M-1b - 8/2 Line Mixer
Tascam PE-40 - 4 Band Parametric Equalizer
Tascam GE-20b - 10Band/2Channel Graphic Equalizer
*it is virtually impossible to find replacement slider caps for this unit.*
Tascam MH-40b - Multi Headphone Amp
Tascam LA-40 - Line Amplifier/Impedance Adapter
Tascam MU-40 - Meter Unit
Tascam PB-32 / PB-64 - Patch Bays
*MISC*
Tascam RS-20 - Dual Spring Reverb
*this spring reverb was released before the rs-20b obviously. the rs-20 was released exclusively in the U.S., and the rs-20b was later released exclusively in Japan.*
Feel free to add to this. I’ll keep it updated. ��
P.S. <3 here are some links with info related to the rack units.
Tascam GA-2020 - http://www.sanyo-densi.com/dai2/effects/tascam_ga2020.htm
Tascam RS-2000 - https://www.hifido.co.jp/sold/16-06337-01555-00.html?LNG=E
Tascam DL-2000 - TASCAM DL2000: ja-radio(じゃーらじ)&#55357;&#56571;/JA1JQE
Tascam GA-30 - Tascam GA-30 Graphic Equalizer w/ Spectrum Analyzer TEAC EQA-30BL Photo #1188277 - US Audio Mart
Tascam RS-20b - Tascam RS-20B Story... -
Tascam DL-20 -
Tascam CF-20 -
Tascam GA-40 -
Tascam MX-80 - https://www.manualslib.com/manual/1014550/Tascam-Mx-80.html
Tascam M-1b - https://reverb.com/item/28554712-tascam-m-1b-line-mixer-w-manual
Tascam PE-40 - https://www.manualslib.com/products/Tascam-Pe-40-3984412.html
Tascam GE-20b - https://www.radiomuseum.org/r/teac_tascam_graphic_equalizer_ge_20b.html
Tascam MH-40b - https://www.manualslib.com/manual/712851/Tascam-Mh-40b.html
Tascam LA-40 - Tascam LA-40 Info Needed
Tascam MU-40 -
Tascam PB-32/PB-64 - https://www.manualslib.com/manual/1399761/Tascam-Pb-32p.html
updated 5/26
