A
ap
Member
An article in Homerecording Mag July 2001 says put monitors along the long wall in a small space, and keep them 1 or 2 feet away from the back wall to avoid early reflections.
Same magazine June 2000 says put 'em on the short wall, and in large print says "The thing to avoid is having a small space between the wall and the speaker. Put the speakers either well away form the wall or right on it." It also explains that 3 feet is the minimum distance if not right on the wall.
What do you think, and is there any way to reconcile the two apparently contradictory ideas.
You will probably find MANY threads in that forum that deal with monitor placement, and possible room treatments that will have you hearing things fairly good without spending a fortune to do it.
