DebErney
I have owned the Tascam DP-24. It was defective as other buyers of this were discovering. I ended up getting it replaced. Seems Tascam is having quality control issues. I thought the DP32 took care of these issues. After finding out Tascam only has 6 month warranty on labor I sold it and and bought a Zoom R-16 which I love and would not part with.
The Tascam has a very large foot print and is heavy. Not something your going to want to lug around. But it did basic recording well. It had a bright, sterile sort of sound. The basic interface was easy. Getting to anything else was through a difficult menu system. The effects were not very usable, at least on the DP-24. I used it for straight recording taking the SD card and mixing my recordings on my MAC with REAPER or Garageband.
The ZOOM R-16 is very light weight, I didn't purchase it earlier because it was so light. I've had it for two years now and not a problem with it. It records with a bit of warmth to the sound, while still maintaining the clearity. I add a slight bit of reverb to all recordings on this. Record to an SD card then to REAPER on the Mac where I add EQ, Compression, Effects, etc...
Editing on either of these would be a challenge because of the small screen and both have menu systems that are not intuitive to use.
A plus with the Zoom is that it can also be used as a computer interface. You have to download and install the drivers from Zoom.com
It does a decent job. The Tascam DP-24 not so much.
I now use an Apogee Duet, I picked up on EBay and there is a difference in sound but, it only records two channels. I still bring my ZOOM to recordings because I know it always works. Turn on, plug in, hit record.
The computer interfaces are so finicky, not for the technically challenged. You have to setup drivers in your operating system and then in your recording program, making sure they each have the same settings. Have to mess with them more than not and when I'm recording in the field, if it doesn't boot up and configure, fast, I pull out the Zoom.
Would I buy the Zoom again and again. MOST DEFINITELY. always does as it's supposed to.
I have made several videos with the zoom and the Tascam. Deb Erney - YouTube
The Tascam was used on the earlier recordings, the zoom on the middle recordings. Most of them are posted with the equipment I've used on them.
