Compressor, 'Verb, Delays... all in one?
  • Thread starter Thread starter HeyHeyMyMy
HeyHeyMyMy
HeyHeyMyMy
Red Member
Hi everyone, I'm relatively new here and haven't had much luck finding an exact answer to my question.
I'm looking to record an acoustic album on my little Tascam PortaStudio 424 MKIII. What I have is, the Tascam, an old Shure SM57, and a couple of ancient guitar stomp boxes (delay, compressor/limiter, etc.). I am running both the compressor/limiter and delay through my effects loop out from the mixer but it doesn't really seem to be doing much. Essentially, I'm not getting the vox effects I am looking for. My question is, can anyone recommend a cheap effects processor that has say, Reverb, Delay and Compression on it that I can run the Vox and possibly the guitar through? Any other suggestions would be great as well. Thanks a lot!
the tc m300 does all that. the compression is uh.. not great, but the reverbs are good for the price. the delays are nice as well. $125 used?
what are you planning on compressing? there are some very affordable outboard compressors that work well. symetrix, art, ashly, etc. you might want to look at a symetrix 525. you can pick them up for $50-$100. almost as nice as an RNC. maybe a bit more fun as well. and those tiny ART levelars aint so bad for a funny color compressor.
ART vs Digitech 300
The ART is compressor-less.
The Digitech looks like the choice for what you're looking for but be warned --- it will be VERY easy to over-process your vocal. ;)
Would you recommend a cheap compressor and cheap standalone reverb unit instead of the multi-effects unit?
Hey Hey, A cheap compressor and standalone 'verb' unit would be OK. Most multi fx units compressors are alright but if you want serious compression then they're probably not up to it. I use a mix of my trusty Zoom 9030 1/2 rack multi fx and the onboard Tascam 788 fx / compressor. But as stated earlier, just a touch or you'll have an over processed sound. I tend to lightly compress on recording, then add more later if needed, same with the reverb fx.
Check out your compressor options in your budget and maybe a multi fx unit for the reverb / delay stuff...
Zeek
Hi Zeek,
I think that is probably what I will do then. I just thought of one other thing, not sure if it's a good idea or not but... I have an old Zoom 8080 SuperPlayer guitar multi effects pedal... it's got about 2 million effects on it, could I run vox through that somehow and use the compression and 'verb off of that? Might be a dumb question.
Hey Hey, absolutey right.. but its a quality issue.. My Zoom has a compressor on it, it's ok but not great.. I wouldn't use it for Vox as it doesn't compress enough..
Sounds like you have your delay / reverb fx covered for now so I'd probably look at getting a compressor first.
Hi Zeekle, any cheap compressors you could recommend?
Try this thread for some ideas on cheap compressors.
https://homerecording.com/bbs/showthread.php?t=119610
I have looked at the Samson C, I thought for what I do it sounded like a good price, not to big and easy to use.. although I have no practical experience of it!!
Zeek
PS if you respond to me from this, don't be offended if I dont answer, am of to Paris for a few days... Z
