famous beagle
I know this is the analog forum, but I thought this might be adjacent enough to fit here.
I am using it with a bunch of analog outboard gear at least!
My company (Hal Leonard) is finally moving offices in Milwaukee after almost 40 years, and so we've all been cleaning everything out. I found this unit sitting in a storage room with a note that said "Free: Don't know if it works." It had the power cord and several MD data discs, so I figured what the hell.
I used to have the original MD4 back in the day (late 90s), but back then, my skill level (both as a musician and engineer) was much worse than today. So I was curious to see what I could get out of this if it worked. I've always loved working with limitations, which is why I always kept a cassette 4-tracker on hand when I wanted to work that way on certain songs. That was the case until about 3 years ago, when, after a run of four or five recorders in a row that all had some technical issue made me rethink that idea. I was just spending too much time trying to fix crap instead of making music. So I decided to let it be and move on.
I've use a DAW system for years with my band recordings and for work, but I still love to work DAW-less when I can, so I got a Tascam DP-24 for that purpose, which I still have. However, this minidisc recorder has awakened that youthful spirit in me once again. Long story short, it's 100% fully functional and in great shape actually. No noisy jacks/pots, etc. It works like new.
While putting it through its paces and testing all the functions, I also tested the MIDI sync capabilities with a drum machine (Behringer RD-78) and with Studio One. In doing so, I recorded this little spontaneous jam. Improvised the main riff (left side), added the other riff (right side), and then added the bass and drums in Studio One.
Guitars: Spark Pedal direct
Bass and drums: EZBass and EZDrummer, synced in Studio One
Outboard gear used:
Compressors (Alesis Micro Limiter, GA Comp-2A)
Effects (Lexicon LXP-1 for reverb, Behringer Vintage Delay guitar pedal for slapback delay on R guitar)
EQ: DOD R-431 (two of them) on the Lexicon reverb return
Anyway, it's been a total blast, and now that I've fully tested it, I'll be wiring it up in the patch bay and setting it up permanently.
Just thought I'd share. Thanks to anyone who read this far.
Outboard gear used:
