D
DenverRob
Greetings,
I have an Alesis 3630 dual-channel compressor. I also have a Yamaha AW16G mulitrack digital recorder. The AW16G has internal compression, which works in the digital realm (after the analog signal has gone through the A/D converter). Where would it be better to compress? I'm thinking it would be best to compress using the external Alesis *prior* to converting the signal to digital. This would allow for the highest possible signal-to-noise ratio prior to digitizing the signal. But maybe I'm wrong?
Related question: I have an external preamp (M-Audio DMP3). I assume the mikes should go into the preamp first, then the compressor (assuming I use the external compressor rather than compress in the digital realm).
Rob
Rob
