M
MatchBookNotes
What effect does this have on the pickups? Is it exactly what one assumes; just turning off one coil to get another sound?
I have coil tapping on my schecter xxx c1 guitar. I love it. I want it on all guitars I get. Gives me a much wider variety of tones. I can have humbucker or single coil tones by just pulling out my tone knob.
I believe "coil tapping" is the less common practice of "tapping" a coil - using only a part of the winding as an option (and as such can be done even to a single-coil pup).
One thing that I haven't seen mentioned, with coil tapping a humbucker, is the volume drop whenever the coil tap is used. My Ibanez JTK2 Jet King has coil tapped humbuckers, and my experience is that the volume drop is a slight inconvenience. Just bump up the guitar volume a tick or two. Lindy Fralin makes a humbucker that's supposed to eliminate the volume drop typical of coil tapping, and is called The Unbucker.
http://www.fralinpickups.com/humbuckers.asp
Matt
Bravo!! You guys are the best. I have an instrument that coil-taps and there is a loss of output. I just change guitars when I want that sound. Caveat: not real practical on a gig. my .02. Keep up the good information.![]()
cool, i was planning to do such a mod when swapping out my humbucker(ala the soldering thread), did you do it yourself?
this may sound like a crazy idea, but could you somhow include a small active boost circuit that is connected to the switch so it only activates when your coils are tapped, eliminating the volume drop common with most coil splits/taps?
something like this maybe
http://store.guitarfetish.com/25migubociti.html
