W
		woldsweather
When I add the CL-1 into the mix I get no sound through at all.
			If you mentioned 'don't need to be clipping' in response to my post, I only intended it to show that the mic was able to put out levels that were adequate enough for the 2i2 and that additional gain from a CL was not needed.6 inches away is ok.
You dont need to be in clipping- territory. Thats ok and normal, actually with low output mics I get my interface preamp at about FULL and get -18db to -12db signals on the DAW meters.
Having the Cloudlifter helps if you use a SM57,58, SM7 then the gain can be 50%-60% and get bigger waves, -12 ..-6db easiy.
This is for spoken word type sound sources, not snare drums and screaming Slipknot vocals.
Condensors mics like SM86, KSM27,32,KSM44 wont work with the Cloudlifter.
			Thanks for your help with this BTW. Test mp3 attached 6 inches from mic with gain full (should it HAVE to be turned up full?).
Are you using the Focusrite drivers and have the Focusrite 2i2 selected as the input source in your DAW similar to the image below
			Yes I updated the drivers a ew days ago on the Focusrite website and here's my audacity screenshot
---------- Update ----------
Do you think the audio level is low then?
sounds like you got it working.
thats a lot of work to get that mic working,
			Im interested in the cloudlifter too. This maybe me being ignorant, but my belief is it changes phantom power to gain. So first you would have to ensure the phantom power on the interface is on, then the lifter would convert it to signal gain. Im interesred in using it to add gain for my dynamics mic only.
That's true, but it's kind of a funny way to describe it. It's an amplifier that runs on phantom power.
I think a better way to describe it is a preamp, than an amplifier., but ibsm a newbe for sure.
