Hi, I'm using a D112 mic on my kick going into CH2. of my DMP3, into input 6 of my Delta 1010lt, using GTPro3. I have the low cut button pressed in on the preamp. The rest of the kit is OK, a couple of over heads and snare, But the kick drum is clipping. I've turned down the gain on the DMP3 all the way down. I've turned down the trim on GTPro for that Channel. and I've turned down the volume for channel 6 on my soundcard. I've moved the mic away from the drum and I sware it was worse. When I listen to playback, the meter isn't clipping, but the wave form is way off the map and you can hear it...it's awfull and I'm upset!!! What's my problem?!?!?
bone
bone
