tubesrawsom
be more carefull next time, but you can use tht clipping to your advantage for some snare dist.
shackrock said:ha. any EE will tell you that clipping is clipping, it's an overload... maybe we can hear it and maybe we can't, but staying away from it prevents hearing it...it's kinda like abstanince...for clipping. HA!
reshp1 said:Not only are you completely wrong about everything else, I'd just like to point out that the above would not work since the key input of the gate will OPEN the gate on every snare hit, not close it.
EDIT, and even if it did work the way you described, having an overhead track that cuts out everytime your snare hits is going to do wonders for your stereo image.![]()
Light said:Ever heard of DUCKING.
I'll listen to anybody who doesn't talk nonsense, and even respect someone who can regularly talk sense.Light said:I have to say, though, that if I already know this shit, I would still be inclined to listen to Aardy.
Light said:I have to say, though, that if I already know this shit, I would still be inclined to listen to Aardy. First of all, he knows his shit. He is talking about what happens in the real world. Sure, it would be nice to avoid all overs, all the time.
Yes I have, it's done with a compressor, not a gate.Light said:Ever heard of DUCKING.
Light
"Cowards can never be moral."
M.K. Gandhi
AGCurry said:It was demonstrated to my ears one time that one of my mixes sounded wimpy compared to a mix of the same stuff which was recorded hotter. My ears told me the truth. The mastering guy I use told me that a few quick overs are inconsequential in comparison to the dynamic-range issue.
Cloneboy Studio said:I would tend to say that he *THINKS* he knows his shit, and has done a good job in convincing you that he does. However, he reminds me of one of those people that gets lost in the little details and misses the whole picture.
reshp1 said:Yes I have, it's done with a compressor, not a gate.
can be used for "Gating" or "Ducking"
DUCKING
In addition to voice over applications, the Duck function of the DS201 may also be used to treat a signal where the peaks are too loud and require attenuating. In this application, 'Duck' and 'Int' modes should be selected, and the 'Range' control adjusted to give the desired attenuation to signals above the 'Threshold' setting. In extreme cases, the ducking action may be used to remove signal peaks altogether, and by careful use of the filters, it may be possible to remove a snare drum from a drum mix or clicks and pops from a recording.
Cloneboy Studio said:I've yet to get a response from his dumb ass about the intelligence of permanently losing data (clipping) for the sake of increasing other data (resolution) that is probably less important to the sound.
He said more than that. if you read the next paragraph, he saysLight said:You do realize, don't your, that he never said anything of the kind, right? He said that a few occasional - small - overs are preferable to losing resolution.
This is the statement that I have a real problem with.AardvarkPSW said:Many high end mastering guys use overage pushing as a "limiting" affect to increase volume.
You only lose resolution during a mix if you are using fixed point math. If the DAW is processing at 32 bit float (most do), no resolution is lost. That is the idea behind the floating point.Light said:Now granted, a slight loss of resolution may not matter much when things are soloed at unity, but when you start cutting them back to fit into the mix, loosing MORE resolution (at least, in the digital domain), it starts to have a very real effect.
Light said:Well, I don't know about you, but every good studio I've ever worked in had a few of THESE, which is what I've always used for ducking. Scroll down a bit, you'll see it.
Yeah, right there. Where it says,
Probably the most common high end gate in the world, as near as I can tell.
Now, from the manual:
Light
M.K. Gandhi
reshp1 said:...some clueless rambling...
