reshp1
Wow, thanks for turning a friendly debate ugly. I still think you're wrong, but don't take my word for itLight said:Ducking is a GATE, and not a compression. Yes, the triggering is different, but a it is not program dependent, which is to say, there is no ratio of output voltage to trigger voltage. When the gate turns on to duck, the signal goes down by x (level of gain reduction) amount. When a compressor goes over a certain level, the output goes down by x times y, where x=level of gain reduction and y=level of input over threshold. There is NO setting on a compressor which will give you a Ducking effect. If your precious "Amateur Toys" program won't let you do that, then that is simply one more thing to complain to them about. But I would bet they have a way of using their gate for ducking.
What part of the difference are you having a problem with? Or have you just never ducked anything?
Light
"Cowards can never be moral."
M.K. Gandhi
http://www.computermusic.co.uk/pdf/tutorials/sidechain.pdf
(3rd page, 1st paragraph "Two of the most useful applications you'll find for compressor sidechains are ducking and de-essing.)
http://www.mikekonopka.com/page26.html
(DUCKING: Ducking can be defined as one signal, or set of signals controlling the limiting/compression of another signal, or set of signals. Suppose you are doing a mixdown in which the producer specifies that the almighty kick drum should take precedence over all other tracks. With ducking, this is easily accomplished. Here's how.....)
http://www.pcmus.com/compressors.htm
(AUDIO "DUCKING"
Ok....This is a cool one for all you Pirate radio owners or Bedroom DJ's.......You know when your listening to the radio, and the music's pumping' away....Then the DJ says something over the music,and as soon as he does, the backing drops in volume a little to make way for the voice......Then when they stop chatting, the music just comes up again to it's normal level.......Well this is known as ducking....and it works like this....
As I mentioned in the Compressor section, the unit listens to the incoming signal through a "Side chain" curcuit......The Side chain gives instructions to the actual compressor by the settings you make in the front panel controls......as soon as the Side chain hears the signal go over the Threshold level, it tells the Amplifier (VCA) at the input to turn down the level....
OK......lets suppose that the music backing is coming through the compressor, but.....the DJ's voice is being fed into the Sidechain........Ah...yes indeed, as soon as the compressor "hears" the DJ's/presenters voice, it turns down the incoming signal .......which is the music backing.......Here's how:
YOUR COMPRESSOR MUST HAVE SIDE-CHAIN SOCKETS ON THE BACK PANEL..... )
Must be a lot of clueless people out there doing a lot of rambling huh?
that's his prerogative, but there is nothing to be done.
