M
Modern_Talking
hello to all
I have done my mixes on my fostex vf160ex recording and now i am trying to put the song on a cd (making an audio cd).
I follow the instruction in the manual i keep getting 1 error. it says "VOID OUT" error which means my clipboard's in/out maybe not set properly. In the manual it doesn't tell you how to setup the clipboard in/out points.
Does anyone know how to or how to get rid of this annoying void out message .
steps:
pressed SETUP key
then went to SAVE PGM
then to IDE
then to CD-DA
then 01 P02 Mymix 00:00 <---- this is where i'm stuck. It should not read 00 . And the note(s) says if the program time reads 00's, adjust the clipboard in and out point.
How do you adjust the clipboard in/out point. The manual doesn't specify that or I can't find it in the manual .
thanks.
steps:
pressed SETUP key
then to IDE
then to CD-DA
thanks.
