D
darkecho
ok, so i know that when using a pan pot, or software, say you have a track of guitar, and a track of vocals
if you pan the guitar 100% left, and the vocals 100% right, the guitar will be the only things coming out of the left speaker and the vocals will be hte only thing coming out of the right speaker.
if you have the vocals not panned at all, then it will seem as though the vocals are coming from down the center (between the two speakers where there isnt a speaker) and is being split 50% into each speaker.
so I dont understand how panning somehting "out of the way" of something else actually works, because you are just adjusting the volumes of the tracks in each speaker, right?
you arent actually moving a sound out of the way, you are just adjusting its relative volume between two speakers right?
or is the Pan pot a physical representation of our psycho-acoustic mind hearing soething that physically isnt happening...
like as you pan a signal from left to right, it appears to be moving in a linear fashion from your left side to your right side, when really the volume in the left is simply dropping as the volume in the right is increasing...
so can your mind place the sounds that it hears as if they were spread in a linear fashion over say a 180degree arc?
