Cheap Condensers
  • Thread starter Thread starter thomaswomas
T
thomaswomas
I've just looked through a recent brochure from a music shop and came across a pair of behringer c-2 condenser mics. they're considerably cheap and wanted to know if anyone has used them before i buy. what's their frequency response? i've already got a good vocal mic so i only need a decent pair of overheads for my bands demos and don't want to break the bank. can anyone give me any pros or cons on these mics?
thanks
simon
Personally I'd pass on the Behringers. For a small condensor look at the MSH, for a large look at a studio projects B1.
I concur with wheelema the studio projects B1 aren't a bad mic for the price it's a good bang for the buck. :)
There freebies they threw em in with all types of gear, some should be floating round here somewhere.
If there giving away I wouldnt think to high of them.
Transducer Type: True condenser, 16mm (0.63 in.) single diaphragm
Operating Principle: Pressure gradient
Polar Pattern: Cardioid
Connection: Gold-plated balanced XLR connector
Open Circuit Sensitivity (at 1kHz): -41dBV (0dBV = 1V/Pa)
Frequency Response: 20Hz – 20kHz
Level Attenuation: -10dB (switchable)
Low-Cut Filter: 6dB/oct. At 120Hz (switchable)
Max. SPL (1%THD @ 1kHz): 140dB (0dB); 150dB (-10dB)
Equivalent SPL (IEC 651): 19dB-A
Signal-to-Noise Ratio: 75dB
Nominal Impedance: 75 ohms
Load Impedance: >1k ohms
Supply Voltage: +48V
Supply Current: 3mA
