B
Beck
Guest
No, you couldn't be more wrong... well, unless we should round up some of your other rambling posts for comparison, to see which is the most wrong. It might be close.
It’s very simple, If you evaluate a high-quality stereo cassette (Nak maybe or whatever) and a high quality Compact disc player in the same system, the change in the width of the sound stage will be obvious, even if your ears are old and tired.
Try the tape first. It would be best if you then record the tape to the CD. When you play the recording on the CD the right and left periphery will be markedly narrowed.
Like the 20k cutoff in frequency response, this phenomenon is measurable and repeatable. it’s the nature of the beast. It’s a well-known limitation of digi.
You can do this experiment in a number of different ways:
You can record the same LP to a good type II cassette and a CD. You can also purchase a commercial CD that is the same as an older tape you’ve had since back in the day (Wednesday?).
Any analog source, including cassette will appear as though the music is actually outside the physical limits of the speakers. CD will seem cropped by comparison. Works with headphones too.
After reading about the phenomenon in the mid 80’s I’ve been privy to several experiments confirming it.
eh... ehm... The point of the post was that even the lowly cassette has a better sound stage IN REFERENCE TO DIGITAL!
Gillett said:What Beck says here is nonsense. Demonstrably so. High quality cassette's stereo soundstage is poor in analog terms, without any reference to digital.
