M
mynameisscott
i suppose i've asked this before but no-one was very clear on how i would do this
I want to be able to mix "hands on" and not mix using the mixer in sonar3.
I know i could mix using a control surface but i dont want to use plugins i want to use ouboard effects to mix with too.
i'll be using a delta 1010 soundcard.
i dont want to record all the tracks and then have to run the signal of a track out of my delta 1010,into a reverb or eq then back into the delta 1010 input and record the new track with whatever effect is use, that would take a long time to mix a song if i had to do that with evry track.
how can i mix using an anolog desk with outboard gear.
for example, i would record a drumkit by setting up all the mics , pluging them into an 8 channel preamp then into my delta 1010,arm the tracks in sonar for recording then record the drums.
After that i'd do the same with bass/guitar/vocals and i'd have a full song.
when i come to mixing it i want to use outboard gear ,
eq's,compressors ,reverb,etc . and i want to mix ''hands on'' .
How would i do this?
again , sorry for asking this before i just didnt realy make it clear on what i wanted.
thanks alot for the help.
