diogo
hi guys,
im havin trouble deciding on some things here, and as im not really experient with voltage or amperes or bits or whatever, im afraid the gear im projecting for the near future might blow itself up cause im makin some rookie mistake..
if you guys could be so cool as to give me a little input on this, u would be saving a fellow RED beast user (have u seen the grey one? http://www.netzmarkt.de/thomann/tho...info.html?sn=f9bd74130532b0b40fb7e50131956bb2 ) from blowing his own setup up and allowing him to keep on makin muuuzik...
here's the setup:
M-Audio DMP3 ----- into ------> Yamaha Rev 500 ------- into -------> Fostex MR8
thats it...now im worried about several things...mainly: voltage, amperes, khz and bits, balanced or unbalanced cabling needed (very confused about this), etc...as the fostex only records at 16 bit, will it take a reverb unit recordin at 24? these kind of things...im in total ignorancy here...here are the specs for each unit:
M-Audio DMP3
2-channel mic/instrument preamp
XLR mic ins; 1/4” instrument ins; balanced 1/4” outs
high 66dB available gain
48V phantom power
20Hz to 80kHz frequency response
2 independent preamp channels, each featuring:
- mic input (balanced XLR)
- high impedance instrument inputs (1/4”)
- high and low gain range controls for up to 66dB of gain
- VU meter and clip LED to aid in optimizing levels
- low-cut filters for removing unwanted rumble and hum
- gain control
- phase reverse switch
- professional line output (balanced/unbalanced 1/4” TRS)
+48V phantom power
frequency response: 20Hz-80kHz, +/-0.5dB @ max gain
signal-to-noise ratio: 116.3dB
THD: 0.05% @ minimum gain
max input: +13.7dBu
max output: +27.5dBu
input impedance: 3K ohms balanced
EIN: -128dBm @ 600-ohms
gain range: 13.5dB to 46.5dB (low gain range)
34.5dB to 67.5 dB (high gain range)
low-cut filter: -3dB @ 72Hz
Yamaha REV 500
Audio Frequency Response: 20Hz - 20kHz (+1, -2dB);
Dynamic Range: 96dB typical, greater than 90dB;
Noise Level: Less than -72dB (IHF-A Filter);
THD: Less than 0.03% (1kHz @max. level, CD 20kHz LPF filter)
AD/DA Conversion AD: 20-bit, 64-times oversampling; DA: 20-bit 8-times oversampling; Sampling Rate: 44.1 kHz
Rear Panel Connectors: INPUT L/R (XLR x 2, phone jack x 2), OUTPUT L/R (XLR x 2, phonejack x 2), FOOT SWITCH (phone jack), MIDI IN, MIDI OUT,(5-pin DIN x 2);
Switches: INPUT LEVEL (+4/-10 Db), OUTPUT LEVEL (+4/-10 Db)
Power Requirements 120 V, 60 Hz, 15 W
Dimensions (W x D x H) 480 x 227.9 x 45 mm (18.9" x 9" x 1.8")
Weight 3.5 kg (7.7 lb.)
Fostex MR8 (i know i dont need to post this one but what the heck..)
Recording Medium : Compact Flash Card
Recording Time : approx. 25 track-minutes (128MB) Normal mode
Recording Format : FAT16 (VFAT)
Sampling Frequency : 44.1 kHz (Normal Mode), 22.05 kHz (Extended Mode)
Quantization : 16-bit linear (non-compression)
A/D Converter : 16-bit Delta-Sigma
D/A Converter : 16-bit Delta-Sigma
No. of Recording Track : 8 tracks. maximum 2 tracks simultaneous recording)
Recording/Reproduction Frequency : 20 Hz - 20 kHz (Normal Mode)
Dynamic Range : 88dB or more (typical)
T.H.D. : 0.05% or less (typical)
Inputs/Outputs
Analog In (2ch)
Connector : XLR-3-31 type (Pin2:hot) and Ø6mm TRS phone
Input Level : -40dBV (MIC) - +10dBV (LINE)
Input Impedance : 10K ohm or more
Stereo Out (L, R)
Connector : Ø6mm stereo phone
Output Level : -10dBV (unbalance)
Load Impedance : 16 ohm or more
Headphones
Connector : 2 x Ø6mm stereo phone
Max. Output : 20mW or more (@32 ohm)
MIDI Out
Connector : DIN 5 pin
Format : MIDI Standard
Foot Switch
Connector : Ø6mm phone
Level : TTL level
Digital Out
Connector : Optical
Format : IEC 60958 (S/P DIF) 44.1kHz (Normal Mode only)
USB
Connector : B type (data save/load controlled from PC)
ok thats it...will this work? and if so, what do i have to do in order to make it work...
tanx in advance and i apologize in advance for the long and somewhat demanding post.
tanx guys!
diogo
here's the setup:
M-Audio DMP3
48V phantom power
- gain control
+48V phantom power
max input: +13.7dBu
Yamaha REV 500
Inputs/Outputs
Analog In (2ch)
Stereo Out (L, R)
Headphones
MIDI Out
Foot Switch
Level : TTL level
Digital Out
Connector : Optical
USB
tanx guys!
diogo
