K
		Kasey
thanks my2cents, i dont know much about drums to be honest so everytime i find something on ebay i'll just run it through you guys for your opinion.
			Kasey said:thanks my2cents, i dont know much about drums to be honest so everytime i find something on ebay i'll just run it through you guys for your opinion.
my2cents said:ok. here's my opinion of the blue sparkle bass drum currently on ebay...i believe the drum is a ludwig. i'm basing that on the lugs, the hoops and what appears to be a white painted shell interior (which dates the drum to pre-1970-ish) and not on the fact that the head says "ludwig". (obviously, any drum can have a head that says "ludwig".) also, it loooks exactly like my 1965 ludwig, but bigger and different color. it looks like there is one lug missing. not a big deal. the cosmetic issues are not a big deal, either (wrinkled drum wrap at the seam...easily fixed or hidden. the seam is usually on the bottom of the drum on ludwig bass drums, so it'd probably be hidden by the floor and it wouldn't affect the sound.). i'd say that is an excellent drum.
worth noting...seller wants $85 for shippnig.
Kasey said:thank you.... i would get it but $85 for shipping is a bit much, ill have to think about it, i might not even have that much
Kasey said:well.. it seems this idea is going to be harder than i thought. There are virtually no shops that carry used drums in Saint Louis, at least not that i have found, and I've called every store in the yellow pages. This will take longer than i thought - and its going to be even harder to find a used 28" bass drum. I really don't want to use ebay because i cant hear it but i might have to...
Kasey said:alright... i'm having an incredibly hard time finding these drums... I'm starting to think I should consider building them. At least the 28" bass drum. How hard would this be? Am i going to have to suddenly learn how to be a master craftsman just to get a halfway decent sound? could someone give me a few pointers here because im pretty cautious about this idea... i'm afraid ill totally screw it up. what wood should i get, where should i look for hardware, what kind is best, how should i do it....etc.etc.etc.
 my2cents said:that stinks. i would have thought st. louis (that's where you are, right?) would have a lot of music stores that could help you out.
i just remembered, if you find an old marching snare drum make sure to measure the head to see if it is a size that is still common. my grandfather gave me a drum of this type that he got from the aleppo temple shriner band. it was a huge hassle finding a head that would fit a drum with a diameter of 16 3/4 inches. i had to buy a 17 inch head, which are (or were a few years ago) still being made, but are virtually impossible to find. i had to order one from a shop somewhere in chicago.
 Tim Brown said:But it will let you know how a 28" Kick will sound.
Recorded with a D112 mounted inside pointed on the mallet strike spot, and an 8" speaker in front, on the resonant side, with a packing blanket over the front of the kick and the 8" speaker.( I put velcro strips on the blanket so I could fasten it around the drum's lug screws to hold it in place.) Full head on the reso side.
Tim
Kasey said:that sounds pretty cool... i was thinking there would be a little more sustain to it though... sort of like a cannon sound. maybe i should consider going even bigger? (no! he dares to suggest it!)
or would you have gotten this sound if you didnt put the pillow in there... i'm liking it though, and ill definetly check out your link.
oh... and that 40" bass drum..... holy shit...
PhraseMMX said:Here is an idea that might be worth trying:
You could use a 14 x 14" floor tom as your snare drum!
Take the snares / strainers / bottom hoop off a normal snare drum and fix to the bottom of the 14x14. (make sure the snare has the same number of lugs as the floor tom - probably 8 - because most goods snares have 10 lugs but you will find plenty with 8) You will also have to use sand paper to form snare beds on the bottom bearing edge of the floor tom. A snare bed is just a depression in the bearing edge at the point where the snare wires will be. Look at the bottom bearing edge on a wood shell snare drum for reference.
I would suggest using an 18x16 bass or floor tom for your rack tom. Pearl optimount is probably the only tom holder that could support a drum that size I reckon!
There is a Scottish band called "Soarpatrol" that use massive toms mounted on Pearl optimount tom holders. They played recently at a Terry Bozzio drum clinic at the SECC in Glasgow (Soarpatrol were the support act) They have a website but it seems to be down at the moment!
Good luck with the massive kit!
You are completely insane though!
Phrase
my2cents said:that's an excellent idea. the only problem is that 14" depth is a long way for air to travel in order to set the snare wires in motion. still, it's worth trying. i have turned a 13" tom into a snare and it worked pretty well. i had to get a shorter set of snare wires and drill holes in the bottom rim for the snare wire fasteners to pass through. i used a file to dig the snare beds (finished off with sand paper for smoothness). unfortunately it was a (VERY) cheap drum and the lugs basically ate themselves as a result of the high tension and constant beating that all snare drums take. if i ever find some good quality lugs for a decent price i'll probably fix it. it sounded quite good.
